In DQL, timeseries and makeTimeseries produce array-like series, so multiplying two series directly (BounceRate * Count) isn’t supported – that’s why you see the “not allowed to multiply arrays” error.
But for this use case IMO you don’t really need to multiply two series. If EmailBounced is 1 for a bounced email and 0 otherwise, then:
BounceRate = bounced / sent
Count = sent
Weight = BounceRate * Count = bounced.
You can compute everything with a simple summarize over 15-minute buckets, for example:
This gives you one row per 15-minute interval with Sent, Bounced, BounceRate, and your “weighted” value (Weight). You can then base your alert on Weight (for example, fire only if the number of bounced emails in a 15-minute interval exceeds a certain threshold
