Is it possible to simply ping a device?
Hello.
I want to know if it is possible to simply perform a ping to a device that does not have OneAgent installed? I don’t know if it is possible using a Dynatrace plugin or maybe there is a possibility to create my own plugin to do this?
Thank you in advance
Hi Cyrill,
At the moment, our plugins run on agents and they can only execute calls locally to where they are running. We are working on a new feature which will allow us to run plugins externally which would then satisfy your use case.
KR,
Kristof
What is the use case behind the ping? Is this to make an availability check?
Hello. Yes exactly I want to perform availability check on devices where it is not possible to install oneAgent. For example, switches, Access point, NAS, etc.
someone has an idea ? @Alexander S. or @Kristof R.
Hi Cyrill,
As I mentioned in my earlier comment, at the moment no external pings can be done with plugins. This is planned for early next year and will allow you to execute plugins towards targets that cannot be instrumented with a OneAgent. In a first iteration this could allow us to have support for known devices such as an F5. Later-on that can be extended.
Cheers,
Kristof
You can also perform the pings outside Dynatrace environment and just send the availability/performance data into Dynatrace using API. More details here:
However the execution itself is up to you.
Hi Kristof,
You mentioned some years ago about that Dynatrace is working on a new feature but I’m wondering if any Plugins was created already, we also want to perform availability check on devices where it is not possible to
install oneAgent
Regards
Carlos
I’ve built a simple ActiveGate plugin to ping devices (measures response time and availability). It creates custom devices. Works quite well for many devices.
Anything you would like to share?
I’ll check it within our company if we are allowed to share it.
Hi Julius, I have a case of monitoring some communication devices by ping, it is possible you can share your plugins, I would appreciate it.
We actually attend a HOT Day training session where we used a Dynatrace Plugin from an activegate to run Port pings. SO it is possible from within Dynatrace to do pings, we pinged a website, not sure if you can apply the same method to a device
Hi @Julius L. Are you able to share the activegate plugin?
Thank you,
Mike
One of our clients has not requested this, for web monitoring we use http monitor, but we want to reach the devices.
Thanks!
Best regards.
Marcelo Santander.
I wrote a blog post which covers this and it has a link to the ping and port extensions from it: Easily monitor your entire infrastructure with Dynatrace Synthetic monitors
Mike
Thanks !
Best Regards!!
Marcelo Santander
There is in Dynatrace Hub a synthetic monitor ping that you can use.
Just some additional two cents on this: the extensibility of Dynatrace is very good, and in our case we have even built an extension that pings with 1 second resolution, enabling the possibility of having strong network SLA measuring, in both latency & availability. I’m in the process of trying to solve a dependency issue, to make it available.
Good!!
That is actually the tile from my team for the blog post I linked.
Good luck!
