# Is Kafka monitoring possible?
**URL:** <https://community.dynatrace.com/t/is-kafka-monitoring-possible/18934>\
**Category:** Extensions\
**Tags:** kafka, extensions, apache\
**Created:** [December 24, 2018, 9:07am UTC](https://community.dynatrace.com/t/is-kafka-monitoring-possible/18934 "2018-12-24T09:07:34Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![suresh230591](https://dub1.discourse-cdn.com/dynatrace/user_avatar/community.dynatrace.com/suresh230591/32/280_2.png) [@suresh230591](https://community.dynatrace.com/u/suresh230591)\
**Post date:** [December 24, 2018, 9:07am UTC](https://community.dynatrace.com/t/is-kafka-monitoring-possible/18934/1 "2018-12-24T09:07:34Z")
</div>
With the latest plugin for Kafka monitoring. I could see Broker, Controller and Network metrics but there is no information about the topics. Earlier I was using custom plugin from git where few broker metrics are split by Topic names. So we were having Individual char for each Topic. Do we have similar functionality in new plugin.
Suresh
**Author:** ![skrystosik](https://dub1.discourse-cdn.com/dynatrace/user_avatar/community.dynatrace.com/skrystosik/32/21133_2.png) [@skrystosik](https://community.dynatrace.com/u/skrystosik)\
**Post date:** [December 24, 2018, 9:41am UTC](https://community.dynatrace.com/t/is-kafka-monitoring-possible/18934/2 "2018-12-24T09:41:40Z")
</div>
I think current version of the plugin is limited to this functionality, but there is always option to disable embedded plugin and instal that one that you have used previously. Embedded one is developed by Dynatrace itself so if you want something more for it pleas add new RFE in product Ideas and it is possible that they will consider you request 🙂
