# Issue with OneAgent Installation: Unable to Determine Connection Status
**URL:** <https://community.dynatrace.com/t/issue-with-oneagent-installation-unable-to-determine-connection-status/47999>\
**Category:** Dynatrace Managed\
**Tags:** oneagent\
**Created:** [September 26, 2024, 2:16pm UTC](https://community.dynatrace.com/t/issue-with-oneagent-installation-unable-to-determine-connection-status/47999 "2024-09-26T14:16:45Z")\
**Posts on this page:** 8\
**Page:** 1
<div class="post-metadata">
**Author:** ![Salma\_berechid](https://avatars.discourse-cdn.com/v4/letter/s/c5a1d2/32.png) [@Salma\_berechid](https://community.dynatrace.com/u/Salma_berechid)\
**Post date:** [September 26, 2024, 2:16pm UTC](https://community.dynatrace.com/t/issue-with-oneagent-installation-unable-to-determine-connection-status/47999/1 "2024-09-26T14:16:45Z")
</div>
**Hello,**
I hope you’re doing well.
I have a problem with OneAgent. The ActiveGate is installed on a server, and when I tried to install OneAgent on another server, I got the following error:
_“Unable to determine Dynatrace OneAgent connection status (oneagentos did not start). For details, see: /var/log/dynatrace/oneagent/installer/installation\_384754.log”_
OneAgent’s status is inactive. Could you please help with that?
Thank you.
Salma
**Author:** ![AntonPineiro](https://dub1.discourse-cdn.com/dynatrace/user_avatar/community.dynatrace.com/antonpineiro/32/49_2.png) [@AntonPineiro](https://community.dynatrace.com/u/AntonPineiro)\
**Post date:** [September 26, 2024, 3:06pm UTC](https://community.dynatrace.com/t/issue-with-oneagent-installation-unable-to-determine-connection-status/47999/2 "2024-09-26T15:06:17Z")
</div>
Are you executing shell script with root privileges?
Best regards
**Post date:** [September 26, 2024, 3:09pm UTC](https://community.dynatrace.com/t/issue-with-oneagent-installation-unable-to-determine-connection-status/47999/3 "2024-09-26T15:09:58Z")
</div>
Thank you for your response.
Yes.
Best regards,
**Post date:** [September 26, 2024, 3:38pm UTC](https://community.dynatrace.com/t/issue-with-oneagent-installation-unable-to-determine-connection-status/47999/4 "2024-09-26T15:38:15Z")
</div>
And do you have connectivity to ActiveGate from server?
Best regards
**Post date:** [September 26, 2024, 3:40pm UTC](https://community.dynatrace.com/t/issue-with-oneagent-installation-unable-to-determine-connection-status/47999/5 "2024-09-26T15:40:28Z")
</div>
Yes it’s connected to ActiveGate.
Best Regards,
Salma
**Post date:** [September 26, 2024, 4:26pm UTC](https://community.dynatrace.com/t/issue-with-oneagent-installation-unable-to-determine-connection-status/47999/6 "2024-09-26T16:26:55Z")
</div>
I would raise a support ticket about this.
Best regards
**Post date:** [September 27, 2024, 8:07am UTC](https://community.dynatrace.com/t/issue-with-oneagent-installation-unable-to-determine-connection-status/47999/7 "2024-09-27T08:07:37Z")
</div>
Yes, I did and the problem was solved.
Thank You.
Salma
**Post date:** [September 27, 2024, 8:10am UTC](https://community.dynatrace.com/t/issue-with-oneagent-installation-unable-to-determine-connection-status/47999/8 "2024-09-27T08:10:13Z")
</div>
To anyone facing the same issue, the problem was that the watchdog files did not have the necessary permissions. Simply grant the appropriate permissions, and it should work.
Best Regards,
Salma
