Java BufferPool Monitoring
Would like to monitor BufferPool Memory consumed for a java Microservice. Can anyone please advise on the possibilities through Dynatrace.
getMemoryUsed
Rajendra
You can find here all JVM metrics out-of-the-box.
If it not there, you can explore JMX extensions.
Best regards
One addition/note to Anton’s reply - JMX extensions likely would be the way to go but that documentation links to the 1.0 extensions framework which will still be around for quite a while but the latest way to handle these is within the 2.0 extensions framework.
https://developer.dynatrace.com/develop/dynatrace-extensions-vscode/guides/migrate/jmx-conversion/
