JMX extension - JBoss Connection Pools
Hi
Does anyone have documentation about these JBoss Connection Pools metrics ?:
- Total pool time
- Total get time
- Total usage time
I searched in jboss documentation and I found the following, but nothing about the previous ones:
https://access.redhat.com/documentation/it-it/jboss_enterprise_application_platform/6.3/html/administration_and_configuration_guide/datasource_statistics
thanks
Antonello
You have this extension and you can see with metrics are involved in the bottom.
Best regards
Hi Anton
In this document I found just the following, without any metric description:
Metric name Metric key Description Unit
Total blocking time jboss.connectionPool.TotalBlockingTime.count - MilliSecond
Total creation time jboss.connectionPool.TotalCreationTime.count - MilliSecond
Total pool time jboss.connectionPool.TotalPoolTime.count - MilliSecond
Total get time jboss.connectionPool.TotalGetTime.count - MilliSecond
Total usage time jboss.connectionPool.TotalUsageTime.count - MilliSecond
Thanks and regards
I found some descriptions in a different RedHat doc page: https://access.redhat.com/documentation/en-us/red_hat_jboss_enterprise_application_platform/7.2/html-single/performance_tuning_guide/index
  • Total pool time: The total time spent by connections in the pool.
  • Total get time: The total time spent obtaining connections.
  • Total usage time: The total time spent using connections.
Note that in Dynatrace these are being reported as ‘counter’ metrics so the number you’ll see is the delta/change from the previous interval as opposed to the constantly growing value you’d see if you checked these values yourself.
