JSON parsing: fieldsAdd or
I have a DQL which filters down to one of two possible JSONs:
content = {"code":"an_error_code","error":{"code":"an_error_code","message":"An error message appears here..."}
or
content = {"level":"error","message":"Some error here..."}
The output I want is: timestamp + error code (or empty string) + error message. So far, I have:
fetch logs
| filter k8s.namespace.name == "default"
| filter contains(content, "error")
| parse content, "JSON:parsedJSON"
| fieldsAdd error_code = parsedJSON[error][code], error_message = (parsedJSON[message] or parsedJSON[error][message])
This should do it
data record(timestamp=now(), content = """{"code":"an_error_code","error":{"code":"an_error_code","message":"An error message appears here..."}}"""),
     record(timestamp=now(), content = """{"level":"error","message":"Some error here..."}""")
| fieldsAdd error_code = parsedJSON[error][code], error_message = if (isNull(parsedJSON[message]), parsedJSON[error][message], else:parsedJSON[message])
| fieldsAdd output=concat(toString(timestamp),"--- ",error_code, " ",error_message )
| fields output
Simpler way to express:
is using coalesce function
error_message =coalesce(parsedJSON[message], parsedJSON[error][message])
Kris
