Hi, we are considering reducing the monitoring of some K8s namespaces to be able to contain license usage. We use the Classic fullstack, we have applied some rules of Container monitoring
However, even if we have applied this rule we still see the monitored namespace and cannot exclude it. Do you have any solution or had a similar experience or if you have other advice for the reduction of monitored entities would be really helpful.
Thanks ![]()
