I would like to know if there are any Grail labs that I can try out right now. If anyone has it, please share.
If you have an account on Community then you should be able to log into the test environment (Dynatrace).
You can find all the documentation with examples for Grail here:
Radek
Thank you very much, I was able to access everything you told me.
But the lab I want is to experiment from starting with ingest logs to using the incoming logs to set up other uses.
Chayaphot
In that case, it will be best if you set up a new trial account and play with the environment for 15 days.
I recommend using the EasyTravel app for testing: https://community.dynatrace.com/t5/Start-with-Dynatrace/easyTravel-Documentation-and-Download/m-p/181271
Radek
