Log monitoring v2 resource question
Hi Folks,
Sometimes when we swich on log monitoring on new sources we face reqularly trimmed logs however we do not see any resouce issues on dt managed servers (self portection works well :-)).
Which resource should be increased in order to get more cluster managed limit events rate? CPU or RAM or both? Which one has more influnce on it?
https://www.dynatrace.com/support/help/shortlink/managed-requirements#log-mon
Attached a time period when logs were trimmed without managed resource issue.
Managed: (8vcpu, 66GB RAM) *3, cluster managed limit for evenets 26,500 per/minute - > 20k allocated for this environment.
Please advice.
Br, Mizső
Hello @Mizső
You need to increase the memory on each host. Also, you can drop the unnecessary logs to reduce the load.
Regards
Babar
Hi @Babar_Qayyum
Thanks for the suggestion.
Best regards,
Mizső
