Hi everyone,
The problem is Logs not available for MZ level.
MZ level contains Access Environment, and View Logs
Inside the MZ, I have specified
- Aws Account ID equals
- Entities matching type(“host”), entityName.startsWith(“foobar”)
- Entities matching type(“Service”)
- Web applications where name contains “hello”
Using the preview, appeared on Aws Account ID with type AWS Lambda Function
Also, Entities matching type (“Service”), <Lambda name> in <region>, type RPC service
Now, when I go to Applications & Microservices > Services > {Lambda name} in {region} > Related Logs
It’s missing the logs. Only when I gave Environment level : Access Environment and View logs, the logs appears.
Any ideas why?
Thank you
Best Regards,
Abner
