Maintenance window for a particular RabbitMQ queue
Is it possible to create maintenance window for the below mentioned RabbitMQ queue?
Kindly let me know if it is possible.
(builtin:tech.rabbitmq.topN_queue_messages_ready:avg):filter(eq(“dt.entity.process_group”,PROCESS_GROUP-E49647667725FBDE),eq(queue,“mailMessage.mailSender.dlq”))
Thanks in advance
Hello @dhariniu
TL:DR Yes
Long Answer:
Assuming that the sentence is well formed, I recommend you go to Management Zones and create one using entity selector:
And when you create the MW use this:
that does the trick
Thanks much for your response.
i couldnt find “Management Zone Settings”. Does that mean i dont have enough privileges?
Dharini
Yes if you can’t see it for sure you lack the require privilege.
