Managed node installation wget certificate error
Am trying to run the wget command to add a new node to a cluster to make it a 3 node cluster.
However I am getting errors running the wget command indicating unrecognized certificate for the primary node.
I attempted the --no-check-certificate and I still get an error below saying unrecognized option
Is this a bug or an issue with wget command?
How do I resolve or work-around to add a new node?
Hello @echwallah  it appears to be an error with wget. May be you are using an older version of wget with no support for that option, try an update with yum or apt-get. Also you can use options like --ca-directory or --ca-certificate to make wget know your certificate issuer.
Thanks a bunch @DanielS This helped to resolve the issue
