Memory page faults
Hi Folks,
Is it possible to define which process is responsible for the high memory page faults on a host?
Thanks in advance.
Br, Mizső
You can use the data explorer and the metric from the screenshot to see page faults per process group:
Thank you
Hi @bradley_danyo,
Thanks very much for the suggestion. It is a so simple solution. I have never heared about this metric.
Best regards, Mizső
Sure thing glad I could help.  If you’re every curious and looking for a specific metric, you can always try searching in the data explorer or the Metrics tab on the left hand menu of the Dynatrace tenant.
Hi @bradley_danyo
Shame on me. :wink: I have already been using DT since 2019 daily basis… so I would have thought this solution. Thanks again.
Have a nice day.
Br, Mizső
Hi @bradley_danyo & @Mizső
Tried this metric (builtin:tech.generic.mem.pageFaults) in few environments (v254) and its keep return 0, also for Maximum, while the host metric (builtin:host.mem.avail.pfps) return numbers.
In demo environment found numbers for process level but they are not accumulate with the host level
In process we see billions page faults per second
While from host we see just few thousands per second
Any explanation on this odd behavior of the metric per process?
BTW, Is there a place within the UI ,old or new, that we can see this information regarding page faults per process ?
Thanks in advance
Yos
