metric event (Event duration)
Hi All
i have simple case that when some request repeated by certain value per hour ( 100 per hour) send alert
am already done with the calc metric, and almost with the metric event, but i have some confuses about the part of event duration, what shall i put in it
Violating samples
Sliding window
Dealerting samples
appricatie your feedback
Hello Eslam,
you can use duration parameters as following, knowing that Dynatrace get the sample every 1 minute for most of metrics:
Violating samples : Number of times that the threshold is violated.
Sliding window : The duration that you will consider the violating samples in.
Dealerting samples : how many time needed below threshold to close the problem.
Please let me know if you need further clarification.
Islam
Hi Islam
Thanks for you replay
so based on what you mentioned
 i have to devide the 100 request / 60 min to get the right value to use in Violating samples
and at the Sliding window i will put 60 as a min
and at the Dealerting samples i will bet the normal expected requests to consider it  normal per min
if you can give me number for examples it will be great as i  want to consider it problem if the number of requests reach 100 per hour
You can do it as below:
Threshold : 100
Violating samples : 5
Sliding window : 60
Dealerting samples : 5
many thanks. i will try it
if i want if once the threshold reach make a problem i have to make Violating samples 1, right?
Yes, Correct
Hi Isam - one more help.
Below is enviroment level settings for violating samples(for 10 seconds sample)
Violating Sample - 90, Evaluation Window - 90 , Dealerting samples-90 , Evaluation window size for dealerting samples - 30
How do i set the above in the metric event as it is 1 min sample used
