# Metric syntacs
**URL:** <https://community.dynatrace.com/t/metric-syntacs/50446>\
**Category:** Open Q&A\
**Tags:** dynatrace-managed\
**Created:** [February 25, 2025, 10:28am UTC](https://community.dynatrace.com/t/metric-syntacs/50446 "2025-02-25T10:28:43Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![henk\_stobbe](https://dub1.discourse-cdn.com/dynatrace/user_avatar/community.dynatrace.com/henk_stobbe/32/30434_2.png) [@henk\_stobbe](https://community.dynatrace.com/u/henk_stobbe)\
**Post date:** [February 25, 2025, 10:28am UTC](https://community.dynatrace.com/t/metric-syntacs/50446/1 "2025-02-25T10:28:43Z")
</div>
From the documentation I read:
The key of the metric you’re submitting. It consists of sections, separated by dots, for example&nbsp;first.second.third.
Could it be that the max number of sections is 4?
I got some issue’s converting extension 1.0 → 2.0
After build command below error is returned
“code”: 400,
“message”: "Validation errors for asset PROCESS\_GROUP\_INSTANCE:\nGiven property ‘metricSelector’ with value: ‘jmx.ext.aaa.bbb.ccc.99999.dddd.eeee.metric\_Value\_1234567890:splitBy(“dt.entity.process\_group\_instance”)’ Metric selector parse error: line 1:28 at 'dddd\nGiven property ‘metricSelector’ with value: ‘jmx…:splitBy(“dt.entity.process\_group\_instance”)’
(repeats for every metric)
creating a metric with 4 sections saves the day (-;
KR Henk
**Post date:** [February 25, 2025, 10:33am UTC](https://community.dynatrace.com/t/metric-syntacs/50446/2 "2025-02-25T10:33:53Z")
</div>
Sorry found my own answer:
- Custom metrics you can feed to Dynatrace via metric ingestion. These don’t have any fixed prefix, as the&nbsp;[ingestion protocol](https://docs.dynatrace.com/docs/ingest-from/extend-dynatrace/extend-metrics/reference/metric-ingestion-protocol)&nbsp;is completely flexible.
So the conversion from extension 1.0 to 2.0 is ok, but there is still an old check in a schema… Or extension 2.0 uses only classic metrics,KR Henk
