Metrics API For Process Monitoring
I’m trying to utilize the metrics API to pull out alerting based upon process metrics that we have configured.  Does anyone have an example of the syntax that I would need to utilize and what is the ID that I need to relate to a given process when doing so?
You can use the events api to pull all events that were raised on the specific entity(process) either through Davis or through user defined metric events
curl -X 'GET' \
  'https://{environmentid}.live.dynatrace.com/api/v2/events?entitySelector=type%28process_group_instance%29' \
  -H 'accept: application/json; charset=utf-8' \
  -H 'Authorization: Api-Token xxxx'
Through the metrics API you will get very detailed datapoints to the specified metric key.
Metrics related to a process can be a lot so you would need to be more specific with what metric you want.
