Metrics or Nifi
Hi Team,
We  are working on setting up metrics for Nifi which is running on the AWS EC2 as a cluster. We would like to set up metrics for each nifi flow to get the in/out flow files, flow flow file size, etc. Is there a way to get this done in Dynatrace. Already we have installed OneAgent in all out Nifi nodes.
What about using the Nifi prometheus metrics and the prometheus datasource from Dynatrace?
Check also the extensions creator https://www.dynatrace.com/hub/detail/custom-extensions-creator/
Thank you PacoPorro . Let me exlore these options and get back to you with the details.
