Is there is minimum hardware specification recommendation for OpenShift cloud with SaaS setup?
as I am facing High CPU and ram requests.
I dont recall seeing a minimum requirement. Are you using the containerized AG or an external AG - Support Doc: Deployment — Dynatrace Docs
