Missing reset button infrastucture RESET reference period
I do not see a reset button in infrastructure,
The other reset reset buttons (as discussed in below article) are visbke.
Am I missing something?
KR Henk
You have reset button only for:
  • Applications
  • Services
  • Database Services
You can’t reset from infrastructure level.
https://www.dynatrace.com/support/help/monitor/problems/problem-detection/how-to-adjust-the-sensitivity-of-problem-detection/?\_ga=2.97888471.932946420.1544089384-24370806.1544002465
Radek
Note that “resetting” does not make sense for Infrastructure because only static thresholds are used.
