how can we monitor an APP based on the NativeScript version 7 framework (migration to version 8 is already planned) with the JSC runtime (also in the process of being migrated to version V8)?
Angular 11 is used.
Angular 11 is used.
We do not have official support for NativeScript, but it might be possible to instrument an app like that via OpenKit JS [1].
You need to create a “Custom Application” in Dynatrace and then send the data from OpenKit to this custom application’s endpoint. It works similar to mobile applications.
[1] GitHub - Dynatrace/openkit-js: OpenKit JavaScript Reference Implementation · GitHub
