Dynatrace can monitor web properties like UTM campaign, source, medium etc. via RUM as session and action properties.
Can the same be achieved with Synthetic monitoring, to the point where we can check if the tag is 1. present and 2. contains the expected value?
ObservePoint is a tool that can do that and it is quite easy to configure, but due to cost, these checks are only executed every 6 hours. We want to see if Dynatrace can do the same checks, send alerts when an expected tag is not present or has the wrong value and run it more frequently.
I think you can create user action propeties. They can be created base on request attributes also.
Best regards
Sure you can! In Browser Synthetic you can use a JavaScript step to validate of the tag is present on page and fail the test using api.fail method of the tag is not present.
In RUM classic, you could use session or action properties maybe with css selectors too. In the new RUM , I think the right way would be to look for user.events downloading the expected script url. I don’t think new RUM has the option to configure any capuring of the payload as it was in RUM classic.
