# Monitor Prometheus metric not working properly: no metrics with labels
**URL:** <https://community.dynatrace.com/t/monitor-prometheus-metric-not-working-properly-no-metrics-with-labels/30951>\
**Category:** Container platforms\
**Tags:** tagging, kubernetes\
**Created:** [March 29, 2021, 3:15pm UTC](https://community.dynatrace.com/t/monitor-prometheus-metric-not-working-properly-no-metrics-with-labels/30951 "2021-03-29T15:15:54Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![Romanenkov\_Alex](https://dub1.discourse-cdn.com/dynatrace/user_avatar/community.dynatrace.com/romanenkov_alex/32/27497_2.png) [@Romanenkov\_Alex](https://community.dynatrace.com/u/Romanenkov_Alex)\
**Post date:** [March 29, 2021, 3:15pm UTC](https://community.dynatrace.com/t/monitor-prometheus-metric-not-working-properly-no-metrics-with-labels/30951/1 "2021-03-29T15:15:54Z")
</div>
We are successful integrate prometeus metrics in Dynatrace by help page:
> **[Monitor Prometheus metrics](https://docs.dynatrace.com/docs/observe/infrastructure-observability/container-platform-monitoring/kubernetes-monitoring/monitor-prometheus-metrics)**
> Metric ingestion from Prometheus endpoints in Kubernetes, metrics alerts, and monitoring consumption.
Customer replies that there are no metrics with “label”
Also I can`t see limitations or requires for this integration and why I can`t see metrics with labels.
We can see metrics with no label. We can`t see metrics with label.
Is there limitation for this or it is issue and support ticket.
For Customer is very imortant to see metrics with labels. Metrics with no label&nbsp;doesn’t matter.
Thanks.
Alexander
**Author:** ![DavidSeywald](https://dub1.discourse-cdn.com/dynatrace/user_avatar/community.dynatrace.com/davidseywald/32/21182_2.png) [@DavidSeywald](https://community.dynatrace.com/u/DavidSeywald)\
**Post date:** [July 1, 2021, 1:05pm UTC](https://community.dynatrace.com/t/monitor-prometheus-metric-not-working-properly-no-metrics-with-labels/30951/2 "2021-07-01T13:05:20Z")
</div>
Prometheus Metric labels should be visible as dimensions in Dynatrace.
Could you share an example and which Version you are currently on?
There are some limitations:
- We currently only support Prometheus gauge and counter metrics ~~(no histogram or summary type)~~&nbsp; UPDATE: We now also (partially) support summaries and histograms.
- The maximum number of labels per metrics is ~30 (it is actually 50, but Dynatrace also does some dimension enrichment in some cases)
Best Regards,
David
**Author:** ![mreider](https://dub1.discourse-cdn.com/dynatrace/user_avatar/community.dynatrace.com/mreider/32/14971_2.png) [@mreider](https://community.dynatrace.com/u/mreider)\
**Post date:** [March 28, 2023, 12:40pm UTC](https://community.dynatrace.com/t/monitor-prometheus-metric-not-working-properly-no-metrics-with-labels/30951/3 "2023-03-28T12:40:33Z")
</div>
I’d like to refer people interested in Prometheus in Kubernetes clusters to this feedback thread for more input:
[https://community.dynatrace.com/t5/Feedback-channel/Feedback-Channel-for-Prometheus-Monitoring-in-Kubernetes/td-p/208264](https://community.dynatrace.com/topic/208264)
