Monitor Serial interface status running on IEC protocol
Hi Team,
How to monitor gateway service (serial interface status). Its non-IP running on IEC protocol which is non TCP/IP.
@Babar_Qayyum , looking for your comment.
@VibhashMishra,
IEC over serial interface status monitoring is something too specific to be done automatically by Dynatrace.
I would approach this in one of two ways:
  • By monitoring log files where info about this might happen. Not sure if it’s Linux or Windows, but in Linux you might get something from the dmesg logs. In Windows, you might have that info in the Event logs. If so, import them into Dynatrace…
  • If you have a command that you can execute, preferably in python, you can execute it and get the results back into Dynatrace.
