Mount NFS disk?
I’m trying to configure backups and can’t seem to figure out how to mount the NFS target to any of my cluster nodes.
Any insight? What is the linux command that should allow me to do this successfully?
Thanks!
Did you try this guide?
not directly. you have to install NFS support on a dynatrace host? it’s not installed by default?
For dynatrace itself it should have no difference if this is nfs disk or other if it is mounted in OS. So in general it rather Linux question, not DT one. You should follow this or other guide, if there are some dependencies needed you may have to install them.
