Multiple alerts created for 5 minutes sliding window
Timeframe is 16:50 to 16:52 PM.
Alert Configuration is 3 minutes threshold for 5 minutes sliding window , Please refer the Alert Configuration Screenshot.
Custom alert details below:
No Dimension filter applied.
Threshold > 1
Threshold minutes > 3 minutes
Sliding window = 5 minutes
Our Expectation was only 1 alerts for this time frame. But Totally 5 alerts were triggered.
Please refer the Problem Dashboard screenshot and created alerts screenshot.
I haven’t done a lot of log monitoring but based on the screenshots I see each alert has a different action type i.e. GET, ADD & PLAN. If you can share the log file as well would like to understand.
Raj
Please check attached logs file.
logresults-2022-09-20 10_49_52.csv (137 KB)
@Mayank_Sh I haven’t looked into the details of the log file, but wanted to share this behavior I noticed in my environment. We have enabled Custom Alert for NTP drift and we had 10 systems alerted and we have seen 10 alerts vs. a single alert with all the devices. I haven’t played with other alert types to see the behavior. If I find anything with your log will let you know thanks for sharing with us.
