What will be the metric that I need to choose for this if I need to use in a custom chart?
@Jibi U., if you navigate to the Create custom chart and search for the metric" MySQL" you will see all that is available to you for charting. For your image you supplied, you can create a chart with MySQL connections as well as connection errors and it will give you that chart on your desired dashboard.
