Need to create dynamic filter from azure tags
Hello All,
I am trying to add dynamic filters on my dashboard.  Specifically, I want to filter by Azure tags. Is there a way where I can achieve this? Adding tags manually would be a cumbersome task.
Example of Azure tags
Yes, you can use Azure Tags as a dynamic filter.
The filter will show you the available values.
Hey @PacoPorro,
Thank you! That worked. However, it does not filter my dashboard for some reason.  When I try to with [Azure]env tag and select ‘dev’ it does not filter and displays for all environments. Any idea why that would be?
It can be related to the metrics shown in your dashboard.
The metric should contain the dimension related to the filter (Example dimension host if the filter has a host tag)
