Hey all,
Has anyone been able to figure out how to split the Replication Delta metrics by replication partner?
It appears that the Replication Delta information just shows the highest delta observed when it runs repadmin but it doesn’t break it down into a table to show exactly which domain controller is the one that is taking the longest.
Monitor Forest-Wide Replication | Microsoft Learn
For example, I would assume that when the python script is run it would return all of the data in the summary table listed in this MS article where it breaks down the largest detla by domain controller.
Is it possible to do the same using the new extension? I am still using Classic licensing, haven’t made the switch to DPS yet.
Also it appears almost all of the metrics on the classic dashboard are broken, I am able to use the “new” dashboard just fine.
