OCP 3.11 logs can monitor in log V2? If not, is there any workaround to make it work?
Hi @kiranraju ,
On this documentation page, you can check out the list of OpenShift versions supported in Dynatrace:
Dynatrace support lifecycle for Red Hat OpenShift Full-Stack Monitoring
As you can see, OCP 3.11 had end-of-maintenance support on December 2022.
Hopefully, someone from the Community will know the workaround for this problem.
