I am trying to deploy dynakube for arm64 nodes and i am getting the below error:
[2024-04-30 10:58:10.427 UTC] [0004cfb7] [info ] [bootstrapper] Started agent deployment as a container, PID 315319
[2024-04-30 10:58:10.427 UTC] [0004cfb7] [error ] [bootstrapper] Read-only mode is supported only with volume-based storage
Can someone provide some insights to fix this?
But the same configuration works just fine for amd64 nodes. I am using the image tailored for arm64 nodes. Here is my dynakube config:
apiVersion: dynatrace.com/v1beta1
kind: DynaKube
metadata:
namespace: dynatrace
annotations:
feature.dynatrace.com/automatic-kubernetes-api-monitoring: "true"
feature.dynatrace.com/oneagent-readonly-host-fs: "false"
feature.dynatrace.com/automatic-injection: "false"
spec:
apiUrl: https://{environmentid}.live.dynatrace.com/api
tokens: "XXXXXXX"
skipCertCheck: false
namespaceSelector:
matchLabels:
dynatrace.com/inject: "true"
oneAgent:
cloudNativeFullStack:
image: "dynatrace/dynatrace-oneagent:1.277.204.20231129-185056"
version: ""
initResources: {}
nodeSelector:
kubernetes.io/arch: arm64
tolerations:
- effect: NoSchedule
key: node-role.kubernetes.io/master
operator: Exists
key: node-role.kubernetes.io/control-plane
operator: Exists
oneAgentResources: {}
args:
- --set-monitoring-mode=fullstack
- --set-host-group=oa-arm
env:
- name: ONEAGENT_ENABLE_VOLUME_STORAGE
value: "false"
autoUpdate: true
priorityClassName: ""
dnsPolicy: ""
labels: {}
