We have a client who want to monitor CouchDB using OneAgent extension, and the version they are using is 3+, and strangely I have been told by the support that it supports only version 1?
Does anyone have any idea about it? Or how can we monitor it if we have version greater than 1?
It indeed only supports version 1.x. It might work with other versions though, it’s just not been tested by us. You’re the first to ask about it as far as I know so test it out and let us know.
