Reading the below (last) paragraph in the documentation, in regard to OneAgent and code module resource requirements, and recent experiences, I wonder if OneAgent full-stack should be enabled at all, or code modules disabled, when heavy load & stress (performance) tests are performed on an application environment. OA results in cpu overhead, but especially memory impact can be large. Noticed on IIS app pools.
There may be some relevance to Solved: Hotspot section in Service details page of Dynatrace does not show data? - Dynatrace Community
Technology dependent memory demand
OneAgent code modules are optimized to efficiently use memory and to free resources when they’re no longer needed, to burden application execution as little as possible. So, memory demand might vary over application execution time.
Dependent on OneAgent code module, memory demand might peak at application startup. This is especially true for .NET technology. Preparing .NET assemblies for monitoring causes memory footprint to spike, as assembly code temporarily resides twice in memory. This is a known issue of Microsoft .NET technology and can’t be mitigated by Dynatrace OneAgent.
