Oneagent plugins pre loaded on disk
After a scan alert (-; my collegue Joep found the issue in one off the pre-packaged files that are part of the not used "supported technologies.
The screenshot shows the supported technologies dashboad, and the corresponding oneAgent directory/files that are shipped with oneAgent.
I can understand this is a design decision, but what happens if you want to remove one or more files?
KR Henk
I recommend using the API to remove unused plug-ins: Plugins API - DELETE plugin ZIP file — Dynatrace Docs
After removing the plugin from the cluster if there is any residue left on the OA then it can be removed manually.
Radek
