oneagentctl for PPC BE Linux
is the oneagentctl available for PPC BE Linux installation?
My goal is to set up an host group for those kind of host
Thank you
Yes, you have it documented here: Install OneAgent on PPC BE Linux — Dynatrace Docs
Hi dear community member!
This tell me how to install the oneagent for PPC BE Linux and I already did.
Now I need to set up an host group and usually I do it via oneagentctl.
Does the onagentctl exist also for this kind of oneagent installation?
(this is the original question)
Thank you
As the PPC-BE is a PaaS agent version only, it does not support oneagentctl neither host groups. It’s the same as for Solaris. I think I remember this being on the roadmap, maybe @Bartosz G. will share some info.
Hello.
Is there Infra-Only option in ppcbe in LINUX?
Thank you.
@Theodore_x86 , no, there is no such option.
