Hi all,
When user first connect to Dynatrace, we have several built-in dashboards that users can subscribe to in order to get notified if some anomalies happen.
With SaaS, unfortunately there are limitation on what Dynatrace can provide, mainly the backend process but we hope with the initial built-in dashboards, users can get comfortable setting up their own depending on their requirements.
Davis Health Self-Monitoring:
1. Keeping track of all types of event that got processed in Dynatrace.
2. Displaying the number of metric dimensions per Metric Events or Log Events configuration.
3. Allow users to know which Alerting Profile and Notification Integration triggers the most notifications.
4. It also shows which integration fail to deliver notifications along with its duration.
DPS Usage Details DEMO:
1. Dynatrace Platform Subsription dashboard shows different billing metrics to help understand and analyze consumption of Dynatrace (DPS) capabilities.
2. Served as a template so user can modify as needed.
Kubernetes cluster overview
Kubernetes namespace resource quotas
Kubernetes persistent volume claims
Kubernetes workload overview
1. These dashboards are used to monitor K8s metrics from cluster all the way down to workload.
2. They also shows other metrics like CPU Throttling and OOM Kills that can help with alerting.
Metric & Dimension Usage + Rejections
1. This dashboard is used when you notice your metric stopped ingesting data or you run into Metric Event throttling.
2. Displaying limit of dimensions per metric along with its reason.
3. Displaying the amount of custom metrics the tenant currently has compare to the limit.
OneAgent Traces – Adaptive traffic management
1. This dashboard is used to monitor how Dynatrace adjusting the incoming traffic to keep the environment working at optimal threshold.
2. Explaining about OA capture rate and what users should do to optimize collecting data from their monitored entities.
Real User Monitoring
Synthetic Monitoring
These are template dashboards that our Dev created to introduce users to different kind of metrics Dynatrace used to monitor user application, sessions, etc.
