Openshift Cluster health metrics
Hi all,
Is there any way to get metrics from the Openshift cluster?. As far as we have check, running the oneagent in the operation nodes, you will get host health metrics from the node itself. A customer has just asked us if we can get metrics not only from the nodes which runs the pods, but also from the cluster, something similar to the info they get using zabbix.
Thanks in advance.
Best regards,
Sergio
Of course it is supported right now! See:
Here you can also see a webinar showing some capabilities:
and a blog posts with recent changes:
