In EF2, typically I have seen that when there is a need to convert the value of a metric, it is done with a “key: func” definition.
Is it safe to do the calculation with the metric. And if so, how is it done, as I have found no example?
Hi Antonio,
Which data source are you using? They do not all have the same functionality.
In general, using a metric selector in the dashboard/alert/UA section is always possible.
It’s WMI. Value is a multiple of 100, so I would like to ingest the real value, dividing it by 100 first…
For that data source you can’t do anything in the data source (with SQL you can handle it by adjusting your query). You’d have to handle it in the metric metadata section, such as this:
metrics:
- key: my_old_metric
metadata:
displayName: My Old Metric
description: My Old metric, it is large
unit: Count
- key: func:my_new_metric
metadata:
displayName: My New Metric
description: My Old metric, but divided by 100
unit: Count
query:
metricSelector: (my_old_metric)/(100)
Thanks @Mike_L ,
It was the “key: func” I was referring to…
I believe it consumes 0.002 DDUs, because it’s two data points, right? Because I’ll be ingesting a lot of them, I’ll maybe have to go with the value and then do calculations in the UI…
Key function metrics only provide an easy way to do metric selectors. They don’t actually store any data, so they don’t consume DDUs.
That’s very good to know. Didn’t know. Thanks @Mike_L !
