is the Dynatrace Integration of Oracle database insights compatible with Oracle 19c?
I only found Oracle version 11g or 12c as compatible here: https://www.dynatrace.com/support/help/how-to-use-dynatrace/databases/analysis/database-insights/
Kind Regards,
Raphael
I think you will have to try, sometimes versions are blocked in dynatrace for untested versions even if they should work. If there is something not officially supported, it may now work at all or in limited mode.
sebastian
Dynatrace Integration (Early Adopter version) of Oracle database insights is compatible with:
- Oracle version 11g to 19c, including the support for:
- Oracle Multitenant
Monitoring results may vary between the SID-based and ServiceName-based endpoints. For SID-based endpoints, Dynatrace monitors connections to the multitenant container database (CDB). For ServiceName-based endpoints, Dynatrace monitors connections to associated pluggable databases (PDBs).
- Oracle RAC
Dynatrace monitors individual node instances (SIDs) only. You can’t use database insights to monitor a cluster or to monitor individual nodes based on the database service that they’re associated with.
- AWS Oracle RDS
