thank you.
I understand that with it you monitor if someone on purpose or not used NOLOGGING transactions and by with you want to identify how many datafiles are reported as unrecoverable.
We’ve tested on Data Guard with PDBs and when the JOIN on CON_ID is in place the query doesn’t return any data.
It should be edited a little bit for example(BUT add also to check from V$DATABASE if the role is PRIMARY !!):
SELECT con_id,file#,
name,
unrecoverable_time,
unrecoverable_change#
FROM v$datafile where UNRECOVERABLE_TIME > (SYSDATE - 1);
SQL> SELECT
DF.FILE#,
DF.NAME,
DF.UNRECOVERABLE_CHANGE#,
COUNT(*) AS FILE_COUNT
FROM
V$DATAFILE DF
GROUP BY
DF.FILE#,
DF.NAME,
DF.UNRECOVERABLE_CHANGE#;
FILE# NAME UNRECOVERABLE_CHANGE# FILE_COUNT
4 +DATADISK/ORA19C/DATAFILE/undotbs1.312.1171006335 0 1
12 +DATADISK/ORA19C/1A4C5B290B813B27E065000000000001/DATAFILE/users.332.1171007223 0 1
13 /u00/app/oracle/product/19.3/dbs/tbs1_data.dbf 0 1
14 +DATADISK/ORA19C/DATAFILE/dynafras.590.1172210439 5004769 1
5 +DATADISK/ORA19C/86B637B62FE07A65E053F706E80A27CA/DATAFILE/system.323.1171006605 0 1
9 +DATADISK/ORA19C/1A4C5B290B813B27E065000000000001/DATAFILE/system.329.1171007215 0 1
10 +DATADISK/ORA19C/1A4C5B290B813B27E065000000000001/DATAFILE/sysaux.330.1171007215 0 1
7 +DATADISK/ORA19C/DATAFILE/users.313.1171006335 4824476 1
8 +DATADISK/ORA19C/86B637B62FE07A65E053F706E80A27CA/DATAFILE/undotbs1.325.1171006605 0 1
11 +DATADISK/ORA19C/1A4C5B290B813B27E065000000000001/DATAFILE/undotbs1.328.1171007215 0 1
3 +DATADISK/ORA19C/DATAFILE/sysaux.311.1171006309 0 1
1 +DATADISK/ORA19C/DATAFILE/system.310.1171006265 0 1
6 +DATADISK/ORA19C/86B637B62FE07A65E053F706E80A27CA/DATAFILE/sysaux.324.1171006605 0 1
13 rows selected.
SQL> SELECT
DF.FILE#,
DF.NAME,
FROM
V$DATAFILE DF
WHERE DF.UNRECOVERABLE_TIME > (SYSDATE - 1)
GROUP BY
DF.FILE#,
DF.NAME,
SQL> SELECT
2 DF.FILE#,
3 DF.NAME,
FROM
V$DATAFILE DF
JOIN V$DATABASE DB ON DF.CON_ID = DB.CON_ID
WHERE
DB.DATABASE_ROLE = ‘PRIMARY’ AND DF.UNRECOVERABLE_TIME > (SYSDATE - 1)
GROUP BY
DF.FILE#,
DF.NAME,
no rows selected
SQL> SELECT CON_ID FROM V$DATAFILE ;
CON_ID
1
1
1
2
2
1
2
3
3
3
3
CON_ID
1
1
13 rows selected.
SQL> SELECT CON_ID FROM V$DATABASE;
CON_ID
0
SQL> SHOW PDBS
CON_ID CON_NAME OPEN MODE RESTRICTED
2 PDB$SEED READ ONLY NO
3 PDB1 MOUNTED
