Oracle Java Messaging Queues
Hi All ,
I want to know whether Oracle Java Messaging queues can be monitored via One agent .
Hi Manupriya,
In case of weblogic I can find them under the Queues menu item. See attached.
Best regards, Mizső
thanks @Mizső  for the quick response . from the screenshots , I see we can monitor the queue size and the metrics revolving around it . Is it possible by any chance that we can see the errors inside the queue . For instance , can i see what message is stuck inside the queue .
Was this automatically detected by oneagent or was the extension editor used? We’re having problems getting our Weblogic queues showing up
Hi @Manupriya
As far as I know you can’t see what individual message is stuck inside the queue.
Best regards,
Mizső
Hi @Kelvin
Jms queues were automatically detected by oneagent. There were not any cofiguration on DT side. Maybe on WL side should be any configuration in order to expose these information (eg. jmx side).
Best regards,
Mizső
