Dante,
I don’t want to elaborate and keep you busy with large amount of docs, but quite ok intro might be found here:
https://hub.packtpub.com/introduction-oracle-service-bus-oracle-service-registry/
Proxy and Business are OSB specific. Customers of mine (large financial institutions) are monitoring their OSB 12c with Dynatrace. Working together, we prepared dedicated sensors, which are helping us to detect “custom services” for both - the Proxy and the Business side of the OSB calls.
For the Proxy, I’d suggest to check:
com.bea.wli.sb.pipeline.MessageProcessor.processRequest(com.bea.wli.sb.pipeline.<strong>RouterContext</strong>)
RouterContext’s getPipelineContext() will let you see the “human readable” Proxy service name.
For the Business:
com.bea.wli.sb.transports.TransportManagerImpl.sendMessageToService(com.bea.wli.sb.transports.<strong>ServiceTransportSender</strong>, com.bea.wli.sb.transports.TransportSendListener, com.bea.wli.sb.transports.TransportOptions)
ServiceTransportSender’s getEndPoint().getServiceRef() will let you see the “human readable” Business service name.
Both Classes are well documented.
These are good to start with. Then, you’d have branches, nodes, pipelines, etc.
PS
I know you’ve asked for OSB Rest, but that’s not necessarily related to so-called Business Service.
BTW
It’s worth to know, OSB was designed to perform async operations - don’t be surprised if you see http response handled in different thread than the initial request - which might be a challenge if OSB Admins wants you to measure the performance of Business part of of the request.
