OS services Monitoring: Infra mode
Do you know if OS Services Monitoring works only in Full Stack mode? Can be used with OneAgents in Infra mode?
And second question. Do we need to restart services for starting monitoring them?
Thank you so much!
Best regards
Hello @AntonPineiro,
it works with both monitoring modes (Full-stack & Infra), and there is no need to restart the OS services to be monitored, at least I’ve tested it on Windows OS and I’m using it since the classic OS service monitoring for Windows
Hi @Mohamed_Hamdy,
Thank you so much! Dynatrace has told me a restart is required. I would make some test about it.
Best regards
For OS Services monitoring when alerts are generated , in the dynatrace console - problems
in the impacted column - OS Service is coming, not the impacted CI. How do we get that?,
I’m also wanting the impacted CI to show. @sundarv1  did you get that somehow?
