Hello friends
Is it possible to monitor my application in Python version 2.7.5 with Opentelemetry?
I can’t find the library because it is an old version.
Thanks for your help.
Python 2.7.x is EOL since year and not more supported (i think 2020).
It isn’t supported by OTEL, but I think you can try any otel build released before 2019 (unsupported) or with OpenTracing (deprecated).
Thanks for your answer.
Do you have an example that you have tested?
Because even before 2019, I could only find python 3+ OTEL libraries. Unfortunately I couldn’t find them for 2.7.
Or can you share a guiding document for OpenTracing?
Best Regards.
