Overloaded storage on ESXi Host XXXXXXX
Using the VMware Integration. We, are getting a lot of “Overloaded storage on ESXi Host XXXXX”
during our backups. I cannot find a way to disable this one alert or put just “Overloaded storage” into a maintenance window.
I’ve had the same issue, and it doesn’t seem to be possible to isolate it at the level that you pretend.
Probably better to POST this as a “Product Idea”.
The setting for the vmware detections are under:
Setting → Anomaly detection → Infrastructure → VMware
