# Panel that displays pods with failure rate more than 50%
**URL:** <https://community.dynatrace.com/t/panel-that-displays-pods-with-failure-rate-more-than-50/43763>\
**Category:** Dashboarding\
**Tags:** dashboards, kubernetes\
**Created:** [January 23, 2024, 5:18am UTC](https://community.dynatrace.com/t/panel-that-displays-pods-with-failure-rate-more-than-50/43763 "2024-01-23T05:18:26Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![srikanthd](https://avatars.discourse-cdn.com/v4/letter/s/b5ac83/32.png) [@srikanthd](https://community.dynatrace.com/u/srikanthd)\
**Post date:** [January 23, 2024, 5:18am UTC](https://community.dynatrace.com/t/panel-that-displays-pods-with-failure-rate-more-than-50/43763/1 "2024-01-23T05:18:26Z")
</div>
- i am trying to make a panel to observe the pods which are having failure rate high.
i can able to filter on pod\_status but not on the pods failure rate.
Can anyone suggest me what should be used as filter condition to achieve this.
**Author:** ![ChadTurner](https://dub1.discourse-cdn.com/dynatrace/user_avatar/community.dynatrace.com/chadturner/32/161_2.png) [@ChadTurner](https://community.dynatrace.com/u/ChadTurner)\
**Post date:** [March 27, 2024, 6:35pm UTC](https://community.dynatrace.com/t/panel-that-displays-pods-with-failure-rate-more-than-50/43763/2 "2024-03-27T18:35:37Z")
</div>
I would do something like this:
 ![ChadTurner_0-1711564437556.png](https://global.discourse-cdn.com/dynatrace/original/3X/3/c/3c986f3144a1642c387e81a1fd0239f48ce1423f.png)
You can further refine it as needed
**Author:** ![PierreGutierrez](https://dub1.discourse-cdn.com/dynatrace/user_avatar/community.dynatrace.com/pierregutierrez/32/5934_2.png) [@PierreGutierrez](https://community.dynatrace.com/u/PierreGutierrez)\
**Post date:** [April 30, 2024, 3:55am UTC](https://community.dynatrace.com/t/panel-that-displays-pods-with-failure-rate-more-than-50/43763/3 "2024-04-30T03:55:14Z")
</div>
Hi&nbsp;[@srikanthd](https://community.dynatrace.com/user/71099)
I think that exist a confused. The pods don’t have a metric like a failure rate.&nbsp;
The metric of “failure rate” it’s in the service. Pods and Services have a relation, but both are not the same.
In One Pod, you can find different process, and that process can give you a traffic of services.
**Pods have a information like :** Status, Age, IP address, containers, Total container restarts.
**Pods have a metrics like :** CPU, Memory .
**Containers in Pod have metrics like:** CPU (usage, shares, % of limit), Memory (cache, physical total, % of limit), etc.
**Services have metrics like :** response time, failure rate, CPU, throutput
I Recommend you identify the services in your process group, and then use the metric&nbsp; :&nbsp; **builtin:service.errors.server.rate** , for the failure rate .
I hope it’s helpfull 💪
