Parsing rules -- occurrence negation
Hi team,
I need a helping hand with the following DQL parsing.
| PARSE content, "
DATA{1,70000}?
('tenantId'|'tenant '|'tenant'|'TenantID'|'TenantId'|'tenantID'|'tenant_id'| 'tenant id'| 'tenant ID'|'Tenant ID'|'Tenant Id')
('\\\\\\\\\\\\\"'|'\\\\\\\\\\\"'|'\\\\\\\\\"'|'\\\\\\\"'|'\\\\\"'|'\\\"'|'\"')? SPACE? [:|=]? SPACE?
('\\\\\\\\\\\\\"'|'\\\\\\\\\\\"'|'\\\\\\\\\"'|'\\\\\\\"'|'\\\\\"'|'\\\"'|'\"')? ([a-zA-Z0-9-_{*}]{32}:tenantID)
I need to fetch all the occurrences I have as tenantId but I should skip _tenant_ and try to fetch  the next thing (i.e. negate underscores before tenant):
This is an example:
  "Label": "messagingListener/processTrigger/processEvent",
  "caller": "generic_subscription.go:411",
  "level": "info",
  "message": "execution doesn't exist in db, proceeding to create it...",
  "periodType": "month",
  "resourceAction": "reload",
  "resourceType": "app",
  "scopemapping": "tenant",
  "spanID": "123412341234",
  "taskId": "123412341234",
  "taskdescription": "v1.app.reload.finished consumption context with tenant, resourceType, resourceAction scope",
  "taskname": "app_v1_reload_finished_with_tenant_resourceType_resourceAction_scope",
  "tenantId": "example-tfEokyGtBk7skpV3-example",
  "timestamp": "2023-11-27T10:00:25.032214397Z",
  "traceID": "km12mkl123mkl"
The outcome of what I am trying to parse should be “example-tfEokyGtBk7skpV3-example”.
Please note that I can’t parse the content as JSON because I’ll be applying this to other
Could you please help me with it?
Thanks in advance!
If you’re just trying to extract that portion of the payload you can do something like this:
parse fieldToParse, "DATA '\"tenantId\": \"' DATA:tenantId '\",' DATA"
Example:
Let me know if that helps.
Thanks Eric but unfortunately it does not apply to my real use case.
I have at least one hundred variations and I have found that whenever I have an underscore (e.g. _TenantID,_tenantID,_tenant, etc) it’ll fetch the wrong string.
Would it be possible to negate the underscore? As the example below to skip _tenant_
Thanks in advance
Hi @MartinBurgos
yes there is a negative look ahead modifier
does this DPL work for you
$tenant = '"'('tenantId'|'tenant '|'tenant'|'TenantID'|'TenantID'|'tenant_id'|'tenant id'|'tenant ID'|'Tenant ID'|'Tenant Id') '"'!>>(','|'_'|EOL);
$tenantId = [a-zA-Z0-9-_{*}]{32};
DATA{1,15000} $tenant DATA? '"' $tenantId '"'
Best,
Sini
Hi @sinisa_zubic,
I was OoO, thanks for the help but it unfortunately, I need to maintain the same structure and if I try to add  !<<(‘_’) , it doesn’t work.
| PARSE content, "
DATA{1,70000}?
To provide you with more context, I need to skip if tenant starts with an underscore like --> _tenantID or _tenant or _tenant_Id
I hope this provides you with some clarification and thanks for the help!
