We need to edit the DDU quotas for all our Dynatrace tenants by ourselves, please add the feature in Environment Management, currently we are only able to configure the Host Units Quotas as the attached image shows.
You should be able to edit DDU quotas for Dynatrace tenants, assuming the proper permissions are in place. I don’t see any image attached, are you able to attach a screenshot to what you are referring to?
Ah, okay. For Dynatrace SaaS, the option to split DDUs across environments is not currently available - but is planned to be implemented.
However, you are still able to view DDU Overviews within each environment under the ‘Accounting’ drop-down in Settings, as well as configure DDU pools to limit the consumption within the environment. You need the Change monitoring settings permission or use an admin account to access the DDU consumption overview page.
More information on this can be found here: Extending Dynatrace (Davis data units) — Dynatrace Docs
-Ryan
Thanks for your reply. We need to split DDUs across environments by ourselves the same like splitting host units, is there a road map on this?
This functionality is eventually planned for release but unfortunately, as of right now, there isn’t a confirmed timeline as to when it will be released
Any more on the timeline to when this wil be implemented?
We need similar UI, preferably an API as well. Is there any update?
Has there been any update on this?
We’re looking to implement the same functionality for assigning the DDUs.
