Dear All,
Is it possible to implement Pods Ownership through the API?
I am familiar with the best practices involving Kubernetes labels and annotations.
Babar Qayyum
Dear All,
Babar Qayyum
For Pods specifically, ownership is applied through Kubernetes labels or annotations. which you are already familiar with it. There’s no direct Dynatrace API to assign ownership to Pods.
However, I think you can still automate this via: Kubernetes API to programmatically apply dt.owner labels to your pods/deployments or CI/CD pipelines to inject the label at deployment time.
Sujit
