We are trying to figure out if such a functionality exists within Dynatrace. So if a batch job is running too long then maybe generate an alert for it. Anyone know if this is possible?
Hi @shakib,
I have two high level ideas:
1. check this AG extension. Maybe you can reuse the code base of it.
Control-M Jobs | Dynatrace Hub
2. Check this ingestion type. Maybe you can collect some input about your PID and ingest it to DT.
script ingest - Dynatrace Community
OneAgent metric API | Dynatrace Docs
I hope it helps.
Best regards,
Mizső
